查看: 716|回复: 0
重忆经典 雷克萨斯LS430经典低趴来袭 气动避震魅力绽放
发表于 2020-8-19 17:44:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Reminiscent of the classic Lexus ls430, classic low lying, aerodynamic shock absorption
雷克萨斯的当家旗舰轿车LS系列,现在已经发展到第五代车型了。跟上一代车型对比,可以说发生翻天覆地的变化,整车变得更加优美大气之余,作为一款15年前的百万豪车,在外观上肯定不能用今天的标准来衡量,毕竟当初人们的审美观和现在还是有差别的,对于车辆外观的接受能力也不如现在那么广泛。这辆雷克萨斯LS430的外观设计比较中规中矩,传统的有棱有角的设计可能不如现在的圆滑设计那么讨人喜欢,但却是当时的主流风格,很多商务车的标准设计都是跟这辆雷克萨斯LS430一样,这辆雷克萨斯LS430可以说是当年日系车的代表作,宽大规整的车身给人一种成稳大气的感觉
The LS series, Lexus's flagship sedan, is now in its fifth generation. Compared with the previous generation of models, it can be said that earth shaking changes have taken place, and the whole vehicle has become more beautiful and atmospheric. As a million luxury car 15 years ago, its appearance certainly can not be measured by today's standards. After all, people's aesthetic outlook was still different from that of today's, and the acceptance of vehicle appearance was not as wide as it is now. The exterior design of this Lexus ls430 is relatively regular. The traditional angular design may not be as attractive as the current sleek design, but it was the mainstream style at that time. The standard design of many commercial vehicles is the same as that of this Lexus ls430. This Lexus ls430 can be said to be the representative work of Japanese cars at that time. The wide and regular body gives people a kind of success A sense of stability
