查看: 804|回复: 0
Mini R56升级之路 改装气动避震
发表于 2020-8-19 16:56:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mini R56升级之路 改装气动避震
Mini R56 upgrade to pneumatic shock absorber
Mini这样一款非常具有个性的品牌,只要购买了Mini的车主,难免会进行一些不同程度的改装,不管是外观还是动力,对Mini改装的人都非常多,今天就为大家带来Mini R56气动避震改装案例。Mini is such a unique brand. As long as the owner of mini has purchased it, it is inevitable that some modifications will be made to different degrees. There are many people refitting mini, no matter in appearance or power. Today, we will bring you the case of mini R56 pneumatic shock absorber modification.
Comfort and handling have always been the two core standards to measure the performance of a car. However, in the first hundred years of automobile development, the two have always been enemies in the eyes of designers, and it is difficult to give consideration to each other. In this regard, many automobile design masters have developed various technologies to solve this problem, but the most significant milestone is the advent of air suspension technology! Compared with the coil spring suspension used in ordinary vehicles, the absolute advantage of air suspension is obvious. First of all, unlike the spring, air has only one fixed stiffness. Through the adjustment of air valve and air pump, its elastic coefficient can be changed. Accordingly, the soft and hard degree of the shock absorber can also be adjusted, so that the comfort is greatly improved. Secondly, the length and stroke of the air spring can also be controlled by the amount of compressed air. So we see a chassis that can be raised and lowered.
