查看: 881|回复: 0
“沃就不一样” VOLVO改装气动避震低趴气势十足
发表于 2020-8-14 17:00:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Wo is not the same" Volvo refitted pneumatic shock absorber, full of momentum
所谓“低趴”,顾名思义,就是将车身的高度降低,看上去就像是趴在地面上的一样。像国内比较有名的“恐高症”圈子里的车友都是属于走这种风格的。其实想做到普通的低趴并不是特别难,只需要安装一个气压避震套件配上加大轮毂就可以,但是想要达到这样的轮胎外八字效果就不是那么容易了,除了前面两点外,轮毂偏距要进行反复调试,保护轮圈与车身尽可能的接近还要能正常行驶这就需要质量的手艺高明了。
The so-called "low prone", as the name implies, is to lower the height of the body, which looks like lying on the ground. Like the domestic more famous "acrophobia" circle of riders belong to this style. In fact, it is not particularly difficult to achieve ordinary low prone, just need to install a pneumatic shock absorber kit with enlarged wheel hub, but it is not so easy to achieve such a "eight character" effect outside the tire. In addition to the first two points, the wheel hub offset should be adjusted repeatedly to protect the wheel rim and the body as close as possible, and to be able to run normally, which requires high quality and craftsmanship Yes.
其实气动避震也就两部分,控制系统和避震!控制系统大概都是电子元件,避震是专车专用,唯独皮囊!心里障碍就在这里!气动避震是Vip或者Hellaflush风格里必不可少的元素,它的升降功能是这种低趴风格里不可缺少的,这就是气动避震悬挂的特殊之处。气压避震,通过改装四支“气压避震+控制器”从而达到在车内随意调节车身高度的目的,很多品牌高端配置车型也会有,它叫做“空气悬挂” 差别在哪?升的没气压避震高,降的没气压避震低,升降速度没气压避震快。通常超跑 高端suv顶配才有的配置。
In fact, pneumatic shock absorbers have two parts: control system and shock absorber! Control system is probably electronic components, shock absorbers are dedicated to special vehicles, only leather bags! Here is the mental obstacle! Pneumatic shock absorber is an essential element in VIP or hellaflush style, and its lifting function is indispensable in this low lying style, which is the special feature of pneumatic shock absorber suspension. Pneumatic shock absorbers, by refitting four "pneumatic shock absorbers + controllers" to achieve the purpose of adjusting the body height in the car at will. Many high-end configuration models of many brands also have them. What's the difference between them? The rising is not as high as the air pressure shock absorbers, and the falling ones are not as fast as the air pressure shock absorbers. Usually, the top configuration of super high-end SUV is available.
