查看: 1001|回复: 0
大块头汉兰达不走寻常路改装AIRBFT空气悬架减震器精品案例
发表于 2020-8-13 16:43:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A case study of refitting airbft air suspension shock absorber by big hanlanda
丰田 Highlander汉兰达有着宽大的车身,拥有创新的、宽敞的内部空间。是丰田家族中的一款大尺寸的SUV,而且,Highlander汉兰达标配了同级别车型中最高标准的安全装备。这款车行驶中非常安静,而且灵敏性超凡,将多功能性和驾驶舒适性汇于一身。
Toyota Highlander Highlander has a wide body and innovative, spacious interior space. It is a large-size SUV in the Toyota family, and the Highlander Highlander is equipped with the highest standard safety equipment in its class. This car is very quiet in driving and has excellent sensitivity. It combines multi-function and driving comfort.
什么是减震器
减震器可使车辆轮胎与路面保持良好接触
减震器不仅能提高驾乘舒适性,是安全操控必不可少的部分
减震器可支撑轮胎负载重物,确保轮胎与地面的稳固接触及车辆稳定性
减震器为车辆反弹、侧翻、摇摆、刹车和加速后仰提供阻力,从而维持车辆的平衡驾驶
What is a shock absorber?
The shock absorber keeps the tire in good contact with the road surface
The shock absorber can not only improve the ride comfort, but also is an essential part of safe operation
The shock absorber can support the heavy load of the tire to ensure the stable contact between the tire and the ground and the stability of the vehicle
The shock absorber provides resistance for the vehicle to rebound, roll, sway, brake and accelerate to roll back, thus maintaining the balanced driving of the vehicle
减震器的作用是什么?
减震器在车辆转向、刹车和稳定性方面起着至关重要的作用
控制车身和轮胎的过度负荷
减少车辆反弹、侧翻、摇摆、刹车和加速后仰
帮助维持车辆的稳定操控和刹车
帮助维持车轮定位
帮助减少轮胎和其他悬架零部件过早磨损的潜在风险
What is the function of shock absorber?
Shock absorber plays an important role in vehicle steering, braking and stability
Control body and tire overload
Reduce vehicle bounce, roll, sway, brake and accelerate roll back
Helps maintain vehicle stability, handling and braking
Help maintain wheel alignment
Helps reduce the potential risk of premature wear of tires and other suspension components
