查看: 751|回复: 0
"低调猛兽“奥迪RS6宽体+AIRBFT气动避震释放无限低趴魅力
发表于 2020-8-13 15:44:44 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Low profile beast" Audi RS6 wide body + airbft pneumatic shock absorbers release infinite low lying Charm
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。
通过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。
Pneumatic shock absorber with elastic rubber airbag shock absorber, air pressure control system, air storage tank in rear compartment, electronic control system, etc.
Through the air pressure to control the height of the car, is the so-called one low cover three ugly, the ultimate player's favorite is to be able to control the height of the car at will, very successful.
