查看: 657|回复: 0
大众凌渡改装AIRBFT气动避震 低姿态别有风味
发表于 2020-8-13 15:18:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen lingdu refitted airbft pneumatic shock absorber with unique style
“凌渡”二字取意于“凌风渡越”,英文名“Lamando”源于西班牙语中的“Mandar”,意为“指挥、管理、引领与启示”。 大众凌渡一直被大家戏称为“宽体奢适轿跑”,
都说“一低遮百丑,百改降为先 ”,虽然凌渡本身颜值不错,不过网友 还是决定对自己的凌渡进行降低姿态的改动,改装避震不仅能让车更好看,降低重心后也能领车身操控更稳,下面一起来看看车主的凌渡改装避震案例。看看玩家把凌渡改得多么的与众不同。
The word "lingdu" takes the meaning of "lingfengdu", and the English name "lamando" comes from "mandar" in Spanish, meaning "command, management, guidance and Enlightenment". Dazhong lingdu has been jokingly called "wide body luxury car running",
It is said that "one low conceals a hundred ugliness, and a hundred changes should be reduced to the first". Although lingdu's appearance is good, netizens still decide to lower the posture of their lingdu. Refitting the shock absorber can not only make the car more beautiful, but also lead the car body to operate more stably after lowering the center of gravity. Let's take a look at the case of lingdu refitting shock absorbers. Let's see how different the players changed lingdu.
