查看: 875|回复: 0
本想低调,但实力不允许!奔驰C级W205成功改装AIRBFT气动避震
发表于 2020-8-12 16:28:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
I want to keep a low profile, but the strength is not allowed! Mercedes Benz C-class w205 successfully refitted airbft pneumatic shock absorber
奔驰C级W205自发布以来,因家族化的外观,常备人们称为小S级,而现在新款E级上市后,又沦落为小小S级了,不过不管怎么样,不变的事实就是奔驰C级W205绝对是同级别中最吸引颜值控的车型,本期小编就为大家带来奔驰C级W205改装案例
Since the launch of Mercedes Benz C-class w205, it has been called small S-class because of its familial appearance. Now, after the new E-class comes into the market, ihas been reduced to a small S-class. However, the unchanging fact is that the C-class w205 is definitely the most attractive model in the same class. This issue of the minor edition brings us the modification case of Mercedes Benz C-class w205.
本想低调,但实力不允许!创造属于自己独一无二的外观潮流,谁说一定要跟风?
用最实用的气压避震,搭配出自己心里想要的风格,一切自己做主!
千遍一率的样子行径在路上都被湮没了。
款式的造择,决定你的外型,决定别人的目光的方向!
To create a unique appearance trend of your own, who said that you must follow the trend?
With the most practical pneumatic shock absorber, match the style you want in your heart, and make your own decisions!
Thousands of times a rate of the appearance of behavior on the road were annihilated.
The choice of style determines your appearance and the direction of other people's eyes!
如今的改装车友,开始在走自己的独特路线,为的就是展现自身的品位。HellaFlush改装就是目前最能展现品味的改装风格。可能都发现了越来越多的车向“下”向“外”发展,越来越多的车的外观有股说不出的味道,看似暴规,又类似VIP,但是总有点形似但神不似的游离。恭喜你,可能这些车都在走一个共同的路线---HellaFlush。
Today's refitting car friends, began to take their own unique route, in order to show their own taste. Hellaflush modification is currently the most tasteful retrofit style. It may be found that more and more cars are developing from "down" to "outside". The appearance of more and more cars has an indescribable smell. It seems that they are violent rules and VIP, but they are always a little bit like but not divine. Congratulations, maybe these cars are all on the same route - Hella flush.
