查看: 735|回复: 0
奥迪A5空气避震改装 完美绅士变身
发表于 2020-8-12 15:49:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
奥迪A5空气避震改装 完美绅士变身
Audi A5 air shock absorber remodel perfect gentleman
奥迪A5 是一款时尚的五门轿跑车,不仅造型时尚,又能满足家用需求,优雅的溜背设计更让奥迪A5非常适合走外观改装路线的车型,经典的奥迪A5车型进行改装,外观方面整体改装效果并不是特别突出,最重点的部分在于改装了整套AIRBFT空气避震系统及电控单元,可以随心玩转低趴。
Audi A5 It is a fashionable five door coupe, which not only has a fashionable shape, but also can meet the household needs. The elegant sliding back design makes the Audi A5 very suitable for the model with the appearance modification route. When the classic Audi A5 model is refitted, the overall modification effect is not particularly prominent. The most important part is to refit the whole set of airbft air shock absorber system and electronic control unit, which can be as you wish Play low lying.
