查看: 810|回复: 0
“跑车只最”保时捷展现AIRBFT气动避震引领低趴潮流
发表于 2020-8-11 16:44:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Sports car is the best" show airbft pneumatic shock absorber leads the trend of low lying
保时捷(Porsche),德国豪华汽车品牌,又译波尔舍,总部位于德国斯图加特,是欧美汽车的主要代表之一,以生产高级跑车闻名于世界车坛。
Porsche, a German luxury car brand, is headquartered in Stuttgart, Germany. It is one of the main representatives of European and American cars. It is famous in the world for producing high-end sports cars.
减震器,作为汽车改装圈内被动刀最多的部件,不管是初尝改装的萌新还是资深的改装老鸟,都一直将减震器作为车辆改装的第一步。那么为什么这么多人推崇对减震器的改装?改装减震器对车辆又有什么好处呢?下面我们就一起来了解一下。
Shock absorber, as the most passive knife part in the car refitting circle, has always regarded the shock absorber as the first step of vehicle modification, whether it is Meng Xin who has just tasted the modification or senior modification old bird. So why do so many people admire the modification of shock absorbers? What are the benefits of refitting shock absorbers? Let's take a look at it.
