查看: 817|回复: 0
丰田埃尔法气动避震悬挂改装完美分享案例
发表于 2020-8-10 17:52:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
丰田埃尔法气动避震悬挂改装完美分享案例
Perfect sharing case of Toyota Erfa pneumatic suspension modification
埃尔法以卓然而至高的汽车制作标准,借当代汽车制造工艺之精粹,呈现出独一无二的顶级享受,全车采用航空复合材料与铝镁合金完美演绎全模具制式生产,轻量化车身,完美地融合了高性能技术、无与伦比的品质和材质选择。不仅刷新完美座驾的驾乘标准,诠释了极致尊享的致臻含义。
With outstanding and high automobile production standards and the essence of modern automobile manufacturing technology, ELFA presents a unique top-level enjoyment. The whole vehicle adopts aviation composite materials and aluminum magnesium alloy to perfectly deduce the full mold production. The lightweight body perfectly integrates high-performance technology, unparalleled quality and material selection. It not only refreshes the driving and riding standard of perfect car, but also interprets the meaning of ultimate enjoyment
丰田埃尔法豪华商务车,移动的大面包,这款车玩改装肯定属于另类,但是冷门也会有爆款出现,国内也有几台改的非常不错的埃尔法,有兴趣的人可以欣赏一下,今天这台埃尔法安装AIRBFT气动避震悬挂套件,玩姿态的同时提升一些舒适何乐而不为!
Toyota ELFA luxury business car, mobile bread, this car play refit certainly belongs to another category, but there will also be popular, domestic also have a few very good modified Erfa, interested people can enjoy it, today this ELFA is equipped with airbft pneumatic shock absorber suspension kit, play posture at the same time to improve some comfort, why not!
