查看: 785|回复: 0
奥迪R8改装AIRBFT气动避震悬挂案例介绍
发表于 2020-8-10 16:16:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A case study of Audi R8 refitting airbft pneumatic suspension
奥迪R8是奥迪超跑系列高性能跑车,强劲的V8和V10发动机、全时四轮驱动系统和奥迪全铝车身空间框架结构,赋予了奥迪R8出众的动力性能,以及在赛道和公路上的卓越表现。今天我们不说它的动力性能,我们来介绍一下奥迪R8的姿态魅力
Audi R8 is a high-performance sports car of Audi super running series. Its powerful V8 and V10 engines, all-time four-wheel drive system and Audi all aluminum body space frame structure give Audi R8 outstanding dynamic performance and excellent performance on track and road. Today, instead of talking about its power performance, let's introduce the posture charm of Audi R8
AIRBFT专用气囊:
Like airbft special car special leather bag, the use of natural rubber ingredients than tire natural rubber ingredients more! Single fatigue times 3 million to 5 million times, normal use of 3-5 years no problem! All the airbags are tested by strict testing equipment to test the pressure, and then they can be sold together! The clamp part of the leather bag is compressed by high-pressure locking equipment, and the normal pressure test is at 200psi, explosion-proof! The outer layer of the leather bag is protected by anti-corrosion, rain, sand and dust resistant materials! Give you the safest protection
