查看: 688|回复: 0
与您共享AIRBFT气动避震的精神魅力姿态来袭
发表于 2020-8-7 17:47:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Share with you the spiritual charm of AIRBFT pneumatic shock absorbers.
A good pneumatic shock absorber brand is a high-quality manufacturer, a complete quality assurance and after-sales service system, product market share, market reputation, and market feedback! Responsible installation and modification shop, handling every detail, troubleshooting air leaks, loose abnormal noise, and damping height before delivery! The actual inner needs before the modification, what do you need, how you want to play, whether the effect you want after installation, and whether it is convenient during use.
New AIRBFT three-stage memory version control:
1: Main functions: four-wheel independent lifting, front and rear independent lifting, overall lowering; air tank pressure adjustable, air pump working setting, three-stage memory, mobile APP remote control, automatic ignition rise, automatic flameout, low lying, support, English and many other languages, the remote control panel comes with an LCD display, which mainly displays the air pressure value of the air bag and the air cylinder pressure value of the 4 wheels, and it is safer to experience the fun of using the car that the pneumatic suspension culture brings you.
2: Taiwan’s genuine 32-segment damping soft and hard adjustable shock absorber.
3: Use V360 high-power ultra-quiet pump to inflate faster and quieter.
4: The AIRBFT special skin bag is used, and both the control performance and the comfort performance have reached the best effect of the same level.
5: Solenoid valve group: The surface of the new valve body is treated with wire drawing, which further improves the overall texture of the product.
6: Installation problem: The installation is simple and convenient, and the operation is simple and easy to understand.
7: Product advantages: easy to use with any shock absorber, high versatility, can be combined arbitrarily, and convenient to make a beautiful trunk shape.
The AIRBFT special car leather bag uses more natural rubber components than tire natural rubber components! The number of single fatigue is 5 million to 8 million, and there is no problem with normal use for 3-5 years! They are all subjected to rigorous test equipment for pressure test and fully pressured before they can be sold! Through high-pressure locking equipment in the clamp link of the bladder, the outer layer of the bladder is protected by layers of anti-corrosion, rain-proof, sand-dust and wear-resistant materials!
The working principle of the pneumatic shock absorber is to change the height of the car body by controlling the air pressure, which includes the twisted tooth shock absorber, the air pressure control system and the electronic control system. At auto shows or gatherings of car friends, we will often see a lot of cars lying on the ground. Many people who haven't seen it will wonder how to drive this car. Don't worry, you can get it with one click.
