查看: 694|回复: 0
高尔夫7气动避震改装,给你不一样的驾驶体验!
发表于 2020-8-7 17:40:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Golf 7 pneumatic suspension modification, giving you a different driving experience!
高尔夫7悬挂升级,改装台湾AIRBFT气动避震,前后高低可调范围大,32段阻尼软硬调节!不仅能降低车身,带来低趴姿态,更能提升支撑性,让车辆在转弯变道时侧倾更小,行驶更稳定,操控更随心所欲!
Golf 7 suspension upgrade, modified Taiwan AIRBFT pneumatic shock absorber, large adjustable range of front and rear height, 32-stage damping soft and hard adjustment! It can not only lower the body, bring a low lying posture, but also improve supportability, so that the vehicle can roll less when turning and changing lanes, driving more stable, and handling more freely!
In fact, pneumatic shock absorbers consist of two parts, the control system and the shock absorber! The control system is probably all electronic components, and the shock absorber is dedicated to the car, only the skin! The obstacle is here! Pneumatic suspension is an indispensable element in the Vip or Hellaflush style. Its lifting function is indispensable in this low lying style. This is the special feature of the pneumatic suspension.
You may have found that more and more cars are developing from "down" to "outside". The appearance of more and more cars has an unspeakable taste. It looks like a tyrannical rule and resembles a VIP, but it is always a bit similar. But God does not seem to drift away. Congratulations, maybe these cars are all following a common route---HellaFlush.
Let’s break down the word HellaFlush=Hella Flush, which means there are two parts, one is Hella and the other is Flush. Hella is the abbreviation of Hell of, which means special, very, absolute, and super; Flush means flush. So here are two points to be very clear:
1. The formation of HellaFlush must first satisfy Flush, that is, flush tires, and then be eligible to work hard from Flush to HellaFlush;
2. The height of the vehicle must be as low as possible. From the side of the car, there must be no gap between the tire and the fender.
Now HellaFlush has become an international trend in the appearance of modified cars, becoming more and more popular, and more and more accepted by the public. Regardless of the types of cars, rich or poor, HellaFlush has tended to be a kind of taste certification. So, join the movement together!
