查看: 781|回复: 0
奥迪A4B9旅行版气动避震低趴改装姿态醉人。
发表于 2020-8-7 16:22:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The Audi A4B9 Travel Edition aerodynamic shock absorber is intoxicating with its low-profile modification.
奥迪A4B9的出现让很多爱改装的车友坐不住了,帅气犀利的外观设计,不整一辆改改就安奈不住这个躁动的心。因为改装的魅力着实很大,看着爱车一路改变那种感觉真的很爽。今天我们就来欣赏一下奥迪A4B9改装AIRBFT气动避震的案例介绍!
The appearance of the Audi A4B9 makes many car fans who love to refit can't sit still. The handsome and sharp exterior design makes the restless heart unstoppable unless the car is modified. Because the charm of modification is really great, it's really cool to watch your car change all the way. Today we come to appreciate the case introduction of Audi A4B9 modified AIRBFT pneumatic shock absorber!
Pneumatic shock absorber is a kind of air suspension shock absorber installed on the car. It uses rubber air shock absorber to replace the spring shock absorber of the original car, so that the height of the car can be raised and lowered freely. The car body can be raised on off-road roads and can be used at high speed. Lowered and installed with pneumatic shock absorbers, the passing performance of the car is very good, and the shock absorption performance and comfort are much better than the original car.
So, what is pneumatic shock absorber? The working principle of pneumatic shock absorber is to change the height of the vehicle body by controlling the air pressure, so that the car can pass through. It includes elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronics Control system, etc., it will be more comfortable. At auto shows or gatherings of car friends, we will often see a lot of cars lying on the ground. Many people who have never seen this car will wonder how this car can be so low! A word on the lips, and HellaFlush is a modification style that interprets this sentence to the extreme. In the HellaFlush-style modified car, in addition to the J value, ET value and exaggerated Camber parameters of the wheels are extremely particular, the remaining important issue is to reduce the body. So many friends will directly choose the twisted tooth suspension, because the twisted tooth suspension can not only reduce the height of the vehicle, but also provide sufficient support for the vehicle. It serves multiple purposes and is welcomed by many riders. However, for the ultimate players of HellaFlush, the twisted-tooth shock absorber has long been unable to meet their "low" demand, so pneumatic shock absorbers (inflatable shock absorbers) have won these ultimate players with its ability to flex and extend. Heart.
