查看: 1008|回复: 0
AIRBFT气动避震三段记忆版本手机APP遥控
发表于 2020-8-7 15:48:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
AIRBFT pneumatic shock absorber three-stage memory version mobile phone APP remote control
Pneumatic shock absorber is a kind of air suspension shock absorber installed on the car. It uses rubber air shock absorber to replace the spring shock absorber of the original car, so that the height of the car can be raised and lowered freely. The car body can be raised on off-road roads and can be used at high speed. Lowered and installed with pneumatic shock absorbers, the passing performance of the car is very good, and the shock absorption performance and comfort are much better than the original car.
New AIRBFT three-stage memory version control:
1: Main functions: four-wheel independent lifting, front and rear independent lifting, overall lowering; air tank pressure adjustable, air pump working setting, three-stage memory, mobile APP remote control, automatic ignition rise, automatic flameout, low lying, support, English and many other languages, the remote control panel comes with an LCD display, which mainly displays the air pressure value of the air bag and the air cylinder pressure value of the 4 wheels, and it is safer to experience the fun of using the car that the pneumatic suspension culture brings you.
2: Taiwan’s genuine 32-segment damping soft and hard adjustable shock absorber.
3: Use V360 high-power ultra-quiet pump to inflate faster and quieter.
4: The AIRBFT special skin bag is used, and both the control performance and the comfort performance have reached the best effect of the same level.
5: Solenoid valve group: The surface of the new valve body is treated with wire drawing, which further improves the overall texture of the product.
6: Installation problem: The installation is simple and convenient, and the operation is simple and easy to understand.
7: Product advantages: easy to use with any shock absorber, high versatility, can be combined arbitrarily, and convenient to make a beautiful trunk shape.
