查看: 673|回复: 0
AIRBFT气动避震氮气版本双向阻尼可调节气动套件
发表于 2020-8-7 15:27:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft pneumatic shock absorber nitrogen version bidirectional damping adjustable pneumatic package
1: Main functions: four-wheel independent lifting, front and rear independent lifting, overall lowering; air tank pressure adjustable, air pump working setting, three-stage memory, mobile APP remote control, automatic ignition rise, automatic flameout, low lying, support, English and many other languages, the remote control panel comes with an LCD display, which mainly displays the air pressure value of the air bag and the air cylinder pressure value of the 4 wheels, and it is safer to experience the fun of using the car that the pneumatic suspension culture brings you.
