查看: 814|回复: 0
尼桑G37成功改革气压弹簧AIRBFT气动避震完美减震器
发表于 2020-8-6 15:16:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Nissan G37 successfully innovates pneumatic spring airbft perfect shock absorber
我一直认为,汽车改装是一种追求,一种对个性的追求,或者是满足自己虚荣心的一种方式。今天说说要说的改装就是汽车避震的改装。汽车避震的改装相对来说比较特殊,因为它既能兼顾性能,又能兼顾外观,可以说是双赢。
I have always believed that car refitting is a pursuit, a pursuit of individuality, or a way to satisfy one's vanity. Today's talk about the modification is the modification of the car shock absorber. The modification of automobile shock absorber is relatively special, because it can take into account both performance and appearance, which can be said to be a win-win situation.
There has always been a saying in the car circle, "one low covers a hundred ugliness." Such a famous saying. Even if the car is not good-looking, as long as the body is lowered,It can definitely improve your appearance? Super run all low). So as a modification that can not only improve the appearance, but also improve the controlHow to refit the shock absorber?
空气悬架的优点  空气悬架系统是以空气弹簧为弹性元件利用气体的可压缩性实现其弹性作用的压缩气体的气压能够随载荷和道路条件变化而进行自动调节,不论满载还是空载,整车高度不会变化可以大大提高乘坐的舒适性。空气弹簧悬架因其独特的性能和适应性,正在逐步打入传统的钢板和螺旋弹簧领域。  空气弹簧的运动性能特点是:负载能力可调;弹性系数随负载变化;负载变化肘,固有频率几乎不变;固有频率较低。
The advantages of air suspension the air suspension system takes the air spring as the elastic element, uses the compressibility of the gas to realize its elastic effect. The air pressure of the compressed gas can be automatically adjusted with the change of load and road conditions. No matter full load or no load, the vehicle height will not change, which can greatly improve the riding comfort. Because of its unique performance and adaptability, air spring suspension is gradually entering the field of traditional steel plate and coil spring. The characteristics of air spring's motion performance are: the load capacity is adjustable; the elastic coefficient changes with the load; the natural frequency is almost unchanged when the load changes; and the natural frequency is low.
这些特点决定了空气悬架具有以下优点:
(1)乘坐更舒适安全;
(2)改善车辆的行驶平顺性;
(3)延长轮胎和制动片的使用寿命;
(4)负载变化时车身高度不变;
(6)减少对道路的冲击,保护路面,降低高速公路的维修费用;
(7)延长车辆的使用寿命并增加折旧值。
These characteristics determine that air suspension has the following advantages:
(1) Ride more comfortable and safe;
(2) Improve the ride comfort of vehicles;
(3) Extend the service life of tires and brake pads;
(4) When the load changes, the body height remains unchanged;
(5) Reduce the maintenance cost of electrical, air conditioning, exhaust system, axle, body and chassis;
(6) Reduce the impact on the road, protect the road surface and reduce the maintenance cost of expressway;
(7) Extend the service life of the vehicle and increase the depreciation value.
