查看: 792|回复: 0
"品与智,轻生活“雷克萨斯CT200H改装气动减震器成功完美分享
发表于 2020-8-6 14:35:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Product and wisdom, light life" Lexus ct200h refitted pneumatic shock absorber
喜欢出门时恰好迎上第一缕温和的晨光,也喜欢途中为城市增添一抹靓丽风光。
不出意料的是,每一次不经意的出现,都会成为主角。CT出众的外观设计令人印象深刻,清新不俗之感迎面而来。
即便在都市的浮华中,依然可以找到属于自己的风景。CT的设计亮点显现于每一方寸,即便车顶与车尾也别具动人之美。
I like to meet the first gentle morning light when I go out, and I also like to add a touch of beautiful scenery to the city on the way.
Not surprisingly, every time you inadvertently appear, you will become the protagonist. The outstanding appearance design of CT is impressive and fresh.
Even in the glitz of the city, you can still find your own scenery. CT design highlights appear in every square inch, even the roof and rear of the car also has a moving beauty.
汽车改装界很流行一句话:“一低遮三丑”,尤其是在换上一套漂亮的轮圈以后,不改低车身的话视觉上似乎真的会少了些什么(除非你开的是性能车)。要改低车身自然得换避震了,改装避震器的话不仅能带来视觉上的享受,只要调教得宜还能带来操控、舒适及稳定性方面的提升。今天就让小编由浅至深,谈一谈悬挂系统的改装!
There is a popular saying in the car refitting industry: "one low covers three ugliness". Especially after changing into a set of beautiful wheel rims, if you don't change the low body, it seems that there will be something less visually (unless you drive a performance car). If you want to change the low body, you have to change the shock absorbers. If you refit the shock absorbers, you can not only enjoy the vision, but also improve the handling, comfort and stability as long as they are properly adjusted. Let's talk about the modification of suspension system from shallow to deep!
气动避震器就是安装在汽车悬挂上的空气避震器,它利用橡胶气囊来代替原厂的弹簧,并通过控制器的控制来调节底盘的高度。这简单的一句话概括了气动避震系统的两大组成部分——一部分是悬挂,一部分是控制器。其中橡胶气囊避震器、气压控制系统、储气罐、电子控制系统、气泵、连接管路等必不可少的部件
Pneumatic shock absorber is the air shock absorber installed on the car suspension. It uses rubber air bag to replace the original spring, and adjusts the height of the chassis through the control of the controller. This simple sentence summarizes the two major components of the pneumatic shock absorber system - one is the suspension, the other is the controller. Among them, rubber airbag shock absorber, air pressure control system, air tank, electronic control system, air pump, connecting pipeline and other essential parts
在改装了气动避震后,更加凸显时尚炫酷范儿,在正常行驶时可以根据路面状况的不同自由选择爱车的高度,朋友聚会时一趴到底,相信会为你博得更多关注,在遇到烂路时,提高车身高度,增强车身的通过性,采用的是空气悬挂系统,是目前生产气动避震器历史最悠久的厂家,质量与稳定性更加值得你信赖
After refitting the pneumatic shock absorber, it is more fashionable and cool. When driving normally, you can freely choose the height of your car according to the different road conditions. If you lie down to the bottom during the Party of friends, I believe it will attract more attention for you. In case of bad road, improve the height of the body and enhance the trafficability of the body. The use of the air suspension system is the history of the production of pneumatic shock absorbers The oldest manufacturer, quality and stability more worthy of your trust
