查看: 698|回复: 0
外表运动、内心家用——奥迪A4B9改装AIRBFT气动避震案例
发表于 2020-8-6 13:25:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Exterior sport, inner home -- the case of Audi a4b9 refitting airbft pneumatic shock absorber
买了车不改,不如推下海。这句话让很多车友不能忍受,对于我们这种开不来原厂车的人来说,不改是不可能的。因为改装的魅力着实很大,看着爱车一路改变那种感觉真的很爽。看看这辆奥迪A4的改装效果,你心动了吗?
If you don't change your car, you'd better push it into the sea. This sentence makes a lot of riders can't stand it. For those of us who can't drive the original car, it's impossible to change it. Because the charm of refitting is really great, it's really cool to watch your car change all the way. Take a look at the modification effect of these two Audi A4, are you excited?
AIRBFT专用气囊:
Airbft special airbag:
