查看: 1053|回复: 0
“不甘寂寞的奶爸车”奥德赛RB1改装气动避震悬挂完美姿态
发表于 2020-8-5 14:33:53 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Odyssey RB1 refitted pneumatic shock suspension perfect posture
随着二胎政策放开,本来不温不火的MPV市场,好像穴位一下被打开了一样,各个厂商纷纷推出了自家的MPV。不过在此之前,市场上早就存在着两个元老级的车型,商务代表GL8,和居家代表,奥德赛。而奥德赛,在改装界也同样拥有着MPV的元老级地位。
With the liberalization of the two child policy, the already tepid MPV market seems to have been opened up, and various manufacturers have launched their own MPV. However, before that, there were two veteran models in the market, GL8 for business and Odyssey for home. Odyssey, in the refitting industry, also has the veteran status of MPV.
