查看: 725|回复: 0
十代雅阁改装AIRBFT气动避震悬挂效果分享
发表于 2020-8-4 16:04:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Effect sharing of airbft pneumatic shock absorber suspension modified by ten generation Accord
在气动避震的作用下,把车子降到一个最低的状态、给汽车赋予了灵魂打造了自己的专属!这个就是HellaFlush!HellaFlush不是简简单单一个“范儿”,裡面饱含了太多的执著和艰辛,汗水和等待,一个“范儿”是不能概括的。这是一个不懂的人永远不会达成,懂的人永远不会走错的态度。 最关键的,HellaFlush不分车型,不分高低贵贱
In the role of pneumatic shock absorber, the car to a minimum state, give the car a soul, create their own exclusive! This is Hella flush! Hella flush is not a simple "fan". It is full of persistence and hardship, sweat and waiting. A "fan" can not be summarized. This is a person who does not understand will never achieve, understand people will never go wrong attitude. The most important thing is that Hella flush doesn't differentiate between models, high and low
Hellaflush has become an international appearance trend of refitted cars. With the development and progress of domestic refitted cars, more and more are accepted by the public. HF model has also become a symbol of taste
