查看: 724|回复: 0
皇冠改装AIRBFT气动悬挂避震 Hellaflush风格低趴风
发表于 2020-8-4 15:40:44 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Crown modified airbft pneumatic suspension shock absorber hellaflush style low lying wind
减震器,作为汽车改装圈内被动刀最多的部件,不管是初尝改装的萌新还是资深的改装老鸟,都一直将减震器作为车辆改装的第一步。那么为什么这么多人推崇对减震器的改装?改装减震器对车辆又有什么好处呢?下面我们就一起来了解一下。
Shock absorber, as the most passive knife part in the car refitting circle, has always regarded the shock absorber as the first step of vehicle modification, whether it is Meng Xin who has just tasted the modification or senior modification old bird. So why do so many people admire the modification of shock absorbers? What are the benefits of refitting shock absorbers? Let's take a look at it.
目前市场上主要分两种气动方式,机械式气动避震和电子式气动避震,不用明说,光听见电子这两个字,就知道技术含量比较高。价格上,比机械式气动避震要高,但是稳定性上没有机械式这么可靠。气动避震是一件比较精密的配件,和原厂避震相比完全是一个天一个地。气动避震上各有一个弹性橡胶气囊,气囊其实是一个密闭的压力缸,里面充满了惰性气体和油气混合物。腔体内的压力要比大气压高几倍甚至几十倍左右,再利用活塞杆的横截面积小于活塞的横截面积,来
产生压力差,使活塞杆运动。因为气动避震是比较精密的部件,有气罐装置,不适合在颠簸路段进行剧烈的驾驶。容易导致慢性漏气,引起气压不稳定,气罐内的温度会升高,气动调节就会失去精准度。
At present, there are mainly two kinds of pneumatic shock absorbers in the market, mechanical pneumatic shock absorbers and electronic pneumatic shock absorbers. Needless to say, just hearing the word "electronic", you will know that the technical content is relatively high. The price is higher than the mechanical pneumatic shock absorber, but the stability is not as reliable as the mechanical type. Pneumatic shock absorber is a more precise accessory, compared with the original shock absorber, it is completely one day a place. There is an elastic rubber air bag on the pneumatic shock absorber. The air bag is actually a closed pressure cylinder filled with inert gas and oil-gas mixture. The pressure in the chamber is several times or even dozens of times higher than atmospheric pressure, and then the cross-sectional area of the piston rod is smaller than that of the piston
A pressure difference is created which causes the piston rod to move. Because the pneumatic shock absorber is a more precise part and has an air tank device, it is not suitable for severe driving on bumpy roads. It is easy to cause chronic air leakage and unstable air pressure. The temperature in the air tank will rise, and the accuracy of pneumatic regulation will be lost.
先来分解一下这个单词HellaFlush=Hella Flush 也就是有两个部分,一个是Hella,另一个是Flush。
Hella是Hell of的缩写,意思是特别的,非常的,绝对的,超级的;Flush是齐平的意思。所以这里要非常明白两点:
2. 车身高度一定要尽量低,从车的侧面看绝对不能在轮胎和叶子板之间有空隙。如今HellaFlush已经成为了一个国际化的改装车的外观潮流,越来越流行,越来越被大众所接受,无论类型车种贫富贵贱,HellaFlush已经趋向为一种品味的认证。所以,一起加入这个运动吧!
Let's break down the word hellaflush = Hella flush, that is, there are two parts, one is Hella, the other is flush.
Hella is the abbreviation of "hell of", which means special, extraordinary, absolute and super; flush means flush. So here are two things to understand
2. The body height must be as low as possible, and there must be no gap between the tire and the vane from the side of the car. Nowadays, hellaflush has become an international appearance trend of refitted cars. It is becoming more and more popular and is more and more accepted by the public. No matter what type of car is, hellaflush has become a kind of taste certification. So, join the movement!
