查看: 934|回复: 0
蝴蝶奔完美改装3/8铝合金硬管AIRBFT气动避震
发表于 2020-8-4 15:22:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
蝴蝶奔完美改装3/8铝合金硬管AIRBFT气动避震Perfect modification of 3 / 8 aluminum alloy hard tube airbft pneumatic shock absorber
虎头奔指一款S级的奔驰,生bai产年代从89年到du99年,因外形方正(和新款比),得zhi名虎头奔,蝴蝶d奔指老款的奔驰S600,就是千禧那款,因为它进气扇像蝴蝶的翅膀,因此得名蝴蝶奔。每一细部都经过精密的设计与打造,无论在驾驶性、豪华外表和安全性方面,都达到了顶峰的水平。具备强劲的最新V式12缸双涡轮发动机,拥有让人无比兴奋的装备。它还配置了尖端的主动安全防护系统(PRE-SAFE),率先实现了“现实安全概念”,可预先觉察危险并立即作出预防。2013年5月15日第十代的奔驰S级在德国汉堡进行全球发布。
Hutou Benz refers to an S-class Mercedes Benz. It was born in 1989 to du99. It was named Hutou Benz because of its square shape (compared with the new model). The butterfly Dao Benz refers to the old Mercedes Benz S600, which is the Millennium model. Because its air intake fan is like the wings of a butterfly, it is named butterfly Benz. Every detail has been carefully designed and built, reaching the peak level in terms of driving performance, luxury appearance and safety. With the latest powerful V-type 12 cylinder twin turbine engine, it has extremely exciting equipment. It is also equipped with a cutting-edge active safety protection system (pre-safe), which is the first to realize the "realistic safety concept", which can detect the danger in advance and make immediate prevention. On May 15, 2013, the 10th generation Mercedes Benz S-class was launched in Hamburg, Germany.
改装圈内流行说“一低遮百丑”。在给自己爱车换上一套轻量化、高强度的轮毂后,望着轮胎与翼子板之间一拳有余的空洞,这时绝大多数车主会想到改避震,在降低车身的同时弥补这个空洞。没错,今天的话题就是避震器。一套好的避震器所带来的好处,绝对大大超出你的想象。
In the refitting circle, it is popular to say that "one low covers a hundred ugliness". After replacing their car with a set of lightweight, high-strength wheels, and looking at the hole between the tire and fender, most car owners would like to change the shock absorber to make up for the hole while lowering the body. Yes, today's topic is shock absorbers. The benefits of a good shock absorber are far beyond your imagination,
在改装了气动避震后,更加凸显时尚炫酷范儿,在正常行驶时可以根据路面状况的不同自由选择爱车的高度,朋友聚会时一趴到底,相信会为你博得更多关注,在遇到烂路时,提高车身高度,增强车身的通过性,采用的是空气悬挂系统,是目前生产气动避震器历史最悠久的厂家,质量与稳定性更加值得你信赖
After refitting the pneumatic shock absorber, it is more fashionable and cool. When driving normally, you can freely choose the height of your car according to the different road conditions. If you lie down to the bottom during the Party of friends, I believe it will attract more attention for you. In case of bad road, improve the height of the body and enhance the trafficability of the body. The use of the air suspension system is the history of the production of pneumatic shock absorbers The oldest manufacturer, quality and stability more worthy of your trust
