查看: 847|回复: 0
豪华跑车法拉利成功改装AIRBFT气动避震尽显低趴魅力
发表于 2020-8-4 15:00:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Luxury sports car Ferrari successfully refitted airbft pneumatic shock absorbers show low lying Charm
法拉利 是举世闻名的赛车和运动跑车的生产厂家,总部位于意大利马拉内罗(Maranello),由恩佐·法拉利(Enzo Ferrari)于1947年创办,主要制造一级方程式赛车、赛车及高性能跑车
Ferrari is a world-famous manufacturer of racing cars and sports cars. It is headquartered in Maranello, Italy. Founded by Enzo Ferrari in 1947, Ferrari mainly manufactures Formula One racing cars, racing cars and high-performance sports cars.
今天我们聊一聊避震器这个东西,在玩改装的圈子里对于避震器谈的最多的就是某某品牌某某型号的避震如何,对于很多的新手玩家来说,经过耳濡目染往往只能记住什么避震好或者不好,但实际自己装上用起来又是另一回事,可能你需要了解一点关于避震器的基础知识。
Today, we talk about the shock absorber. In the circle of refitting, the most talked about is the shock absorber of XX brand and model. For many novice players, they can only remember what kind of shock absorber is good or bad after being influenced by it. However, it is another thing to install and use it yourself. Maybe you need to know something about the base of shock absorber Basic knowledge.
AIRBFT专用气囊:
Airbft special airbag:
