查看: 757|回复: 0
奢华尊贵奔驰S320-W140改装AIRBFT气动避震套件成功案例分享
发表于 2020-8-4 14:31:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Successful case sharing of refitting airbft pneumatic shock absorber kit for luxury Mercedes Benz s320-w140
对于奔驰这个品牌,  是非常的受欢迎, 更加倾向于他的安全稳定。 对于奔驰的喜爱,可以说上到老下到小,只要一听是奔驰,第一反应就是奢华尊贵,有钱人以及地位的象征。奔驰的品牌价值也是十分的强大,这一点上是其他的很多品牌都无法比拟的。”这辆奔驰S320的车身设计还是十分的修长的,看上去也是十分硬朗,奔驰S级在D级商务车中也算很有名气的, 这或许就是奔驰S级与生俱来的商务气场,再者就是内饰是奔驰S级的优势,天生就是商务车的格调。
For Benz, this brand is very popular, more inclined to its safety and stability. For Mercedes Benz, you can say from old to young, as long as you listen to Mercedes Benz, the first reaction is the symbol of luxury, dignity, rich people and status. Mercedes Benz has a strong value compared with other brands. " The body design of this Mercedes Benz S320 is very slender, and it looks very tough. The Mercedes Benz S-class is also famous among the D-class business vehicles. This may be the inherent business atmosphere of the Mercedes Benz S-class. Moreover, the interior decoration is the advantage of the Mercedes Benz S-class, and it is born with the style of commercial vehicles.
一直认为,汽车改装是一种追求,一种对个性的追求,或者是满足自己虚荣心的一种方式。
今天说说要说的改装就是汽车避震的改装。汽车避震的改装相对来说比较特殊,因为它既能兼顾性能,又能兼顾外观,可以说是双赢。
在汽车圈内一直有一句话,“一低遮百丑。”这么一句名言。哪怕再不好看的车,只要车身降低下来,绝对能令颜值提高不少 。那么作为一项既能提高颜值,又能提升操控的改装,避震该如何改装呢?
It has always been considered that car refitting is a pursuit, a pursuit of personality, or a way to meet their vanity.
Today's talk about the modification is the modification of the car shock absorber. The modification of automobile shock absorber is relatively special, because it can take into account both performance and appearance, which can be said to be a win-win situation.
There has always been a saying in the car circle, "one low covers a hundred ugliness." Such a famous saying. Even if the car is not good-looking, as long as the body is lowered, it can definitely improve the appearance. So, as a modification that can not only improve the appearance but also improve the control, how to refit the shock absorber?
气动避震是安装在汽车上面的一种空气悬挂减震器,是用橡胶空气减震器代替原车的弹簧减震器,使车身高度自由升降,越野路面车身可以升高,高速上车身可以降低,安装了气动避震的车子通过性很好,减震性能和舒适性都比原车的好很多
