查看: 688|回复: 0
分享英菲尼迪Q50改装AIRBFT气动避震展现HellaFlush风格
发表于 2020-8-3 14:31:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Share Infiniti Q50 modified airbft pneumatic shock absorber to show Hella flush style
今天给大家分享英菲尼迪Q50改装AIRBFT气动避震悬挂的改装案例,后备箱造型灯光设计,满足车友的改装欲望,让原来稍显臃肿的车身更加骨感。同时层次感十分鲜明,该翘的地方翘,该丰满的地方丰满。都说车是男人的第二个老婆,有一个这样的老婆谁会不羡慕呢?一起来欣赏英菲尼迪Q50的气动避震改装魅力!
Today, I'd like to share with you the refitting case of Infiniti Q50 refitting airbft pneumatic shock absorber suspension. The lighting design of the trunk can satisfy the refitting desire of the riders and make the original slightly bulky body more bony. At the same time, the sense of hierarchy is very clear, the place where the warp should be warped and the place where it should be plump should be plump. It is said that the car is a man's second wife. Who would not envy such a wife? Let's enjoy the aerodynamic shock absorber refitting charm of Infiniti Q50!
对于外观控来说,低趴范儿是改装车的首选之一,降低的车身高度,让视觉冲击力直线飙升,快“吃”进车身的轮毂造型,也能让每一个车迷热血沸腾。低趴改装风格可谓是时下最流行的改装风格,纯粹的日本界大佬范儿VIP,衍生而出追求极致的hellaflush,包括来自美国西海岸的DUB,降低车身都是必不可少同时也是最重要的一步改装。正所谓一低遮百丑,低趴带来的美感无疑是不可代替的。爱美之心人皆有之,哪怕是定位年轻,造型运动的中级轿跑车,也渐渐丧失了对低趴姿态独特魅力的抵抗力,逐步加入到极致降低车身的队伍中来。
For the appearance control, low profile is one of the first choices for refitted cars. The reduced body height makes the visual impact soar in a straight line. Fast "eating" the wheel hub shape into the body can also make every fan enthusiastic. At the same time, it can be said that the most important step to reduce the car body style of dush from Japan is to lower the car body style from Japan, and the most important one is to lower the body style of the U.S. It is the so-called low cover hundred ugliness, the beauty brought by low lying is undoubtedly irreplaceable. Everyone has a love for beauty. Even if it is a middle-class sedan car with a young positioning and sports style, it has gradually lost its resistance to the unique charm of low lying posture, and has gradually joined the team of extremely low body weight.
