查看: 764|回复: 0
十代雅阁改装AIRBFT气动避震悬挂效果分享
发表于 2020-8-3 14:22:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Effect sharing of airbft pneumatic shock absorber suspension modified by ten generation Accord
其实颜值是个比较抽象的东西,正所谓萝卜青菜各有所爱,极致运动对上沉稳精主要对比进气格栅、外包围、前脸线条。从前脸设计来看,第十代雅阁拥有着非常有辨识度的前脸设计,夸张的进气格栅以及棱角分明的包围都在彰显其运动特性,拥有的精致的商务气息,发动机盖上的线条,又为整车增添了一分肌肉感。
In fact, beauty is a relatively abstract thing. It is just the so-called radish and vegetables have their own love. The ultimate movement is calm and steady. It mainly compares the air intake grille, the outer surrounding and the front face lines. From the front face design point of view, the 10th generation Accord has a very recognizable front face design. The exaggerated air intake grille and angular surrounding all highlight its movement characteristics. The exquisite business atmosphere and the lines on the engine hood add a muscle feeling to the vehicle.
