查看: 783|回复: 0
豪华轿跑的绝对美人! 奔驰E改装AIRBFT气动避震悬挂
发表于 2020-8-2 15:46:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Absolute beauty of luxury sedan! Modified airbft pneumatic suspension for Benz e
奔驰E级W207有着与生俱来的改装天赋,年轻人的热血沸腾、张扬、个性都在这辆车上展露,而减震在其中扮演着重要的角色,如何选择改装一款减震今天和大家一起来探寻。
Mercedes Benz E-class w207 has its inborn talent for refitting. The enthusiasm, publicity and personality of young people are shown on this car, and shock absorption plays an important role in it. How to choose a shock absorber for refitting is explored with you today.
改装圈内流行说“一低遮百丑”。在给自己爱车换上一套轻量化、高强度的轮毂后,望着轮胎与翼子板之间一拳有余的空洞,这时绝大多数车主会想到改避震,在降低车身的同时弥补这个空洞。没错,今天的话题就是避震器。一套好的避震器所带来的好处,绝对大大超出你的想象!
In the refitting circle, it is popular to say that "one low covers a hundred ugliness". After replacing their car with a set of lightweight, high-strength wheels, and looking at the hole between the tire and fender, most car owners would like to change the shock absorber to make up for the hole while lowering the body. Yes, today's topic is shock absorbers. The benefits of a good shock absorber are beyond your imagination!
