查看: 811|回复: 0
宝骏310W改装AIRBFT气动避震成功案例
发表于 2020-8-2 15:32:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Successful case of Baojun 310W refitting airbft pneumatic shock absorber
One low cover three ugliness is a saying often talked about by motorists in recent years, and Hella flush is a modification style which deduces this sentence to the extreme. In hellaflush style refitted cars, in addition to paying great attention to the wheel hub J value, et value and exaggerated camper parameters, the remaining important problem is to reduce the body. So many friends will directly choose the hinge suspension, because it can not only reduce the height of the car body, but also provide sufficient support for the vehicle, which is welcomed by many riders with one stroke. However, for the ultimate players of Hella flush, the toothed shock absorbers can't meet their "low" demands, so pneumatic shock absorbers rely on itThe ability to bend and stretch won the hearts of these ultimate players
