查看: 960|回复: 0
"卫冕之王"奥迪A6C6改装气动避震悬挂演绎低趴魅力
发表于 2020-8-2 15:11:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"King of defending the crown" Audi a6c6 refitted pneumatic shock suspension to show low lying Charm
奥迪A6  C6在我看来是奥迪在国内最为成功一款车,它成功为奥迪打了“官车”标签,成熟稳重气。虽然现在奥迪越来越年轻化了,给人以科技感,但是C6用扎实做工,经典外观,以及在高速公路与同级别车比起来超乎寻常驾驶体验终成一代经典。
In my opinion, Audi A6 C6 is Audi's most successful car in China. It has successfully labeled "official car" for Audi, which is mature and stable. Although Audi is getting younger and younger, it gives people a sense of science and technology, but the C6 has become a classic with its solid workmanship, classic appearance and extraordinary driving experience compared with its peers on the highway.
车辆悬挂系统是车辆各系统中极为重要的部件,车辆唯一接触地面的部件-轮胎,就是透过悬挂系统来承载车身,车辆的操控性、舒适性,悬挂系统均扮演极为重要的角色,而悬挂系统中,减震器就是影响操控性、舒适性最直接的部件,因此要改善操控或舒适度,最优先考虑的当然就是从减震器着手。
The vehicle suspension system is a very important part of the vehicle system. The only part of the vehicle that touches the ground - the tire - carries the body through the suspension system. The handling and comfort of the vehicle and the suspension system all play a very important role. In the suspension system, the shock absorber is the most direct part that affects the handling and comfort. Therefore, it is necessary to improve the handling or comfort, The top priority, of course, is the shock absorber.
1: Main functions: four wheel independent lifting, front and rear independent lifting and overall lowering; adjustable air tank pressure, working setting of air pump, three-stage memory,Mobile phone app remote control, ignition automatic rise, automatic low prone, support Chinese, English and other languages, remote control panel with LCD display, mainTo display the 4-wheel air bag pressure value and cylinder pressure value, more safely to feel the air shock culture for you to bring car fun.
