查看: 739|回复: 0
“专属安全保镖”阿特兹改装AIRBFT气动避震悬挂低姿态案例
发表于 2020-8-2 14:51:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Case study of "exclusive security guard" ATZ refitting airbft pneumatic shock absorber suspension with low attitude
作为一辆安全性极高的中级轿车  ,曾获得美国公路安全保险协会的最高安全评级,就是来自马自达的阿特兹,在年轻人群中存在感真的不低,来自于他曾经辉煌的传奇经历和偏执的造车理念,"让喜欢我的人满意,不要所有人都喜欢我"就是这么豪横!
As an intermediate car with high safety, ATZ, from Mazda, once won the highest safety rating of American Highway Safety Insurance Association. His sense of existence among young people is really not low, which comes from his brilliant legendary experience and paranoid car making concept. "Let those who like me be satisfied, don't let everyone like me" is so arrogant!
