查看: 762|回复: 0
“虽老犹荣”大众MK6改装AIRBFT气动避震案例
发表于 2020-8-2 14:25:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The case of refitting Volkswagen MK6 into airbft pneumatic shock absorber
改装“不分车龄”“不分界限”!大众MK6高尔夫“虽老犹荣”!
Refit "regardless of vehicle age" and "regardless of boundary"! Volkswagen MK6 Golf "old but proud"!
今天为你带来有别于以往的高尔夫MK6改装风格,这台高尔夫MK6,如果远看,可以说是颜值到了巅峰期,百改降为先,一低遮百丑,降低车身同时操控也有所提升,令我们更全面的了解了高尔夫的钢炮世界。
This golf MK6 is different from the previous golf MK6. If you look at it from a distance, it can be said that the appearance of this golf MK6 has reached its peak. It can be said that it has changed from a hundred to the first. It can cover up all kinds of ugliness at a low level. At the same time, the control is also improved, so that we can have a more comprehensive understanding of the steel gun world of golf.
