查看: 741|回复: 0
年轻时尚现代胜达改装AIRBFT气动避震成功案例
发表于 2020-8-1 15:46:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Successful case of refitting airbft pneumatic shock absorber with young and fashionable modern Shengda
那么,什么是气动避震,气动避震的工作原理就是通过控制气压来改变车身高低,使车通过性更高,其包括弹性橡胶气囊减震器、气压控制系统、后备箱储气罐和电子控制系统等,这样会更舒适。在车展或者车友聚会时,我们会经常看到很多"趴"在地上的车,很多没见过的人都会想这车怎么可以这么低!一低遮三丑是近年来车友们常常挂在嘴边的一句话,而HellaFlush 更是将这句话演绎到极致的一种改装风格。在HellaFlush风格的改装车中,除了对轮毂的J值、ET值以及夸张的Camber等参数极其讲究,剩下的一个重要问题就是降低车身了。那么很多朋友就会直接选择绞牙避震,因为绞牙避震既能降低车身高度,还能提供给车辆充足的支撑性,一举多得,受到不少车友的欢迎。不过对于HellaFlush的那些终极玩家来讲,绞牙避震早已经不能满足他们对"低"需求,所以气动避震(充气式避震器)便凭借着它的能屈能伸的本领赢得了这些终极玩家的芳心
So, what is pneumatic shock absorber? The working principle of pneumatic shock absorber is to change the height of the car by controlling the air pressure, so as to make the vehicle more trafficableIncluding elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system, which will be more comfortable. At the auto show orWe often see a lot of cars lying on the ground when car friends get together. Many people who haven't seen it will wonder how this car can be so lowIn recent years, three ugliness is a sentence often talked about by motorists, and Hella flush is a modification style which deduces this sentence to the extreme.Among the hellaflush style refitted cars, in addition to paying great attention to the J value, et value and exaggerated camper parameters of the wheel hub, the remaining oneThe important thing is to lower the body. So many friends will directly choose the hinge suspension, because the hinge can not only reduce the height of the car body, but alsoIt can provide sufficient support for the vehicle, which is welcomed by many riders. But for the ultimate players of Hella flushIn other words, the twisted tooth shock absorber has been unable to meet their "low" demand, so the pneumatic shock absorber (inflatable shock absorber) relies on its flexibilityAbility has won the hearts of these ultimate players
