查看: 955|回复: 0
宝骏310W成功改装AIRBFT气动避震优势分享
发表于 2020-8-1 11:56:09 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Baojun 310W successfully refitted airbft pneumatic shock absorption advantage sharing
第二、是一种汽车改装风格,可以搜索一下美国的汽车改装风格,其中就有改这种的。停好后把气一放,车子就趴在那里还可以防拖车。(但别乱停车,不防罚单……)
Second, it is a kind of automobile refitting style. You can search for the automobile refitting style in the United States, and some of them have changed this style. Once the gas is released after parking, the car will lie down there and prevent Trailer. (but don't park without a ticket...)
