查看: 701|回复: 0
Toyota puertorico 改装气压避震案 轿跑的姿态魅力
发表于 2020-8-1 11:39:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The charisma of the car running of Toyota PuertoRico refitting pneumatic shock absorber
气动避震改装在当下是很流行的一个改装项目,停车、贴地这样的效果真的很酷,是一些年轻男女喜欢的,这就是气动避震的魅力。很不多不懂的人会认为降这么低 怎么开啊!今天我们就来看看这辆福特野马改装气动避震的效果,能升能降才够爽!
Pneumatic shock absorber modification is a very popular modification project at present. The effect of parking and sticking to the ground is really cool, which is liked by some young men and womenThis is the charm of pneumatic shock absorbers. Very few people who don't understand will think how to drive such a low level! Today we'll take a look at this Ford fieldThe effect of refitting the horse with pneumatic shock absorbers is cool enough to rise and fall!
