查看: 755|回复: 0
"自由不羁"福特野马AIRBFT气动避震悬挂改装案例
发表于 2020-7-30 15:31:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Modification of airbft pneumatic suspension for Ford Mustang
气动避震改装在当下是很流行的一个改装项目,停车、贴地这样的效果真的很酷,是一些年轻男女喜欢的,这就是气动避震的魅力。很不多不懂的人会认为降这么低 怎么开啊!今天我们就来看看这辆福特野马改装气动避震的效果,能升能降才够爽!
Pneumatic shock absorber refitting is a very popular modification project at present. The effect of parking and sticking to the ground is really cool, which is loved by some young men and women. This is the charm of pneumatic shock absorber. Very few people who don't understand will think how to drive such a low level! Today, we can refit the Ford to reduce the shock!
Pneumatic shock absorber is a more precise part. Different from the original shock absorber, there is an elastic rubber air bag on the pneumatic shock absorber. The working principle of the elastic rubber air bag is to fill the sealed pressure cylinder with inert gas or oil-gas mixture, so that the pressure in the chamber is several times or dozens of times higher than atmospheric pressure. The cross-sectional area of piston rod is smaller than that of piston And the resulting pressure difference to achieve the movement of the piston rod. Pneumatic shock absorbers are not suitable for driving on various complicated road conditions. Long term driving on bumpy roads will lead to chronic air leakage, unstable air pressure, temperature rise in the air tank, and eventually lose the accuracy of pneumatic adjustment.
