查看: 606|回复: 0
大众T5改装AIRBFT气动避震配件展示
发表于 2020-7-30 15:08:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen T5 modified airbft pneumatic shock absorber accessories display
1: Main functions: four wheel independent lifting, front and rear independent lifting and overall lowering; adjustable air tank pressure, working setting of air pump, three-stage memory,Mobile phone app remote control, ignition automatic rise, automatic low prone, support Chinese, English and other languages, remote control panel with LCD display, mainTo display the 4-wheel air bag pressure value and cylinder pressure value, more safely to feel the air shock culture for you to bring car fun.
Airbft special car special leather bag, the use of natural rubber ingredients than tire natural rubber ingredients more! The number of single fatigue is 5 million to 8 million3-5 years of normal use, no problem at all! After strict testing equipment to test pressure, full pressure can be sold! The clamp ring in the leather bag
After high pressure locking equipment, the outer layer of the leather bag is protected by anti-corrosion, rainproof, sand and dust resistant materials!
