查看: 746|回复: 0
“钢炮中的典范”大众高尔夫MK6完美改装气动避震优质案例
发表于 2020-7-30 14:49:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"The model of steel gun" Volkswagen Golf MK6 perfect refitting pneumatic shock absorber
改装的案例我们已经见得很多了,这台大众MK6经过改装提升了视觉的冲击力,气动对于喜欢姿态的车友有着非常大的诱惑所以车主选择改装AIRBFT避震,降低了车身的高度,塑造了良好的车身姿态。整体的改装风格偏向于外观的变化, 也体现了车主对于爱车的喜欢。
We have seen a lot of refitting cases. This Volkswagen MK6 has been refitted to enhance the visual impact, and the aerodynamic has a great temptation for the riders who like the posture, so the car owners choose to refit airbft shock absorbers to reduce the height of the body and create a good body posture. The overall refitting style tends to the change of appearance, which also reflects the owner's love for the car.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
Pneumatic shock absorber is a more precise part. Different from the original shock absorber, there is an elastic rubber air bag on the pneumatic shock absorber. The working principle of the elastic rubber air bag is to fill the sealed pressure cylinder with inert gas or oil-gas mixture, so that the pressure in the chamber is several times or dozens of times higher than atmospheric pressure. The cross-sectional area of piston rod is smaller than that of piston And the resulting pressure difference to achieve the movement of the piston rod. Pneumatic shock absorbers are not suitable for driving on various complicated road conditions. Long term driving on bumpy roads will lead to chronic air leakage, unstable air pressure, temperature rise in the air tank, and eventually lose the accuracy of pneumatic adjustment.
