查看: 727|回复: 0
优雅C级低姿态奔驰W205改装气动避震欣赏
发表于 2020-7-30 14:34:09 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Elegant C-class low profile Mercedes Benz w205 refitting aerodynamic shock absorption
本想低调,但实力不允许!
创造属于自己独一无二的潮流风格,谁说一定要跟风?
用最方便实用的气动避震,改装出自己心里想要的风格一切自己做主!
I want to keep a low profile, but the strength is not allowed!
To create a unique fashion style of your own, who says you must follow suit?
With the most convenient and practical pneumatic shock absorber, refit the style you want in your heart, and make your own decisions!
AIRBFT专用气囊:
Airbft special airbag:
