查看: 728|回复: 0
"简约不简单"宝马F10改装HellaFlush风格 强化性能内外兼修
发表于 2020-7-30 12:07:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Simplicity is not simple" BMW F10 refitting hellaflush style to enhance performance and repair both inside and outside
在改装车迷眼中,追求风一样的速度是对心里的一种交代。而提到F10这一代的宝马5系, 很多人的第一印象就是商务味道十足的行政车,拥有一部高性能M系也是一直的追求。但现实是残酷的,不是所有人都用得上M5的动力性能。宝马5系和M5关联起来,倒有那么一丝意味。M5是以5系为基础所衍生开发的高性能车种。这也给了向M系看齐的机会和改装平台。而其实这一代的宝马5系拿来玩改装也能非常漂亮,本期小编就带来一辆内外兼修的宝马F10改装案例。
In the eyes of refitting fans, the pursuit of the same speed is an explanation to the heart. When it comes to the F10 generation of BMW 5 series, many people's first impression is that the administrative car is full of business flavor. Owning a high-performance M-series is also a constant pursuit. But the reality is cruel, not everyone can use the M5 power performance. The connection between BMW 5 series and M5 has a trace of meaning. M5 is a high-performance vehicle developed on the basis of 5 series. This also gives the opportunity to keep up with the M-series and refit the platform. In fact, this generation of BMW 5 series can also be very beautiful to play with and refit. In this issue, we will bring a BMW F10 refitting case with both internal and external repair.
