查看: 832|回复: 0
起亚K5改装AIRBFT气动避震案例经典低姿态
发表于 2020-7-29 14:30:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
起亚K5改装AIRBFT气动避震案例经典低姿态Classic low attitude case of Kia K5 modified airbft
作为曾经屌丝三宝之一的起亚K5,可谓是风靡一时的红人。凭借时尚运动的外观以及较高的性价比,在市场有了自己的一席之地。不过因为产品更新换代不及时,再加上市场等多方面原因,最终成为了落魄的代表。而如今,为了更好提升竞争力,试图重回巅峰,全新一代K5终于要上市了。
Kia K5, as one of the three treasures of losers, is a popular celebrity. With the appearance of fashion sports and high cost performance, it has its own place in the market. However, because the product update is not timely, coupled with the market and other reasons, it has finally become the representative of the down and out. Now, in order to better enhance competitiveness and try to return to the peak, a new generation of K5 is finally coming on the market.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
