查看: 808|回复: 0
“最美无敌”高尔夫7改装AIRBFT气动避震低姿态别有风味
发表于 2020-7-29 12:07:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"The most beautiful and invincible" Golf 7 refitted with airbft pneumatic shock absorber with low attitude and unique flavor
网上曾有段子说道,大众只有高尔夫一款车型,加个屁股是速腾,缩短点是POLO,加长就是帕萨特。虽是玩笑,但也从侧面说明了,高尔夫在大众集团中的灵魂地位。此外,高尔夫还是全球销量最高的两厢车之一,自1976年诞生至今,已经经历了八代的迭代,而今第八代高尔夫7车型也终于要进入国内市场了。
There was a story on the Internet that Volkswagen only has a golf model, adding a butt is a Speedo, shortening point is polo, and lengthening is Passat. Although it is a joke, it also shows the soul status of golf in the Volkswagen Group. In addition, golf is one of the most popular hatchback cars in the world. Since its birth in 1976, golf has gone through eight generations of iterations, and now the eighth generation model is finally entering the domestic market.
高尔夫7简洁有力的线条,勾勒出更为动感、硬朗的造型。加长的车身与更短的前悬彰显全新高尔夫的豪华魅力。气动避震的上身也是醉美无敌了!
The simple and powerful lines of golf 7 outline a more dynamic and strong shape. The longer body and shorter front suspension highlight the luxury of the new golf. The upper body of pneumatic shock absorber is also invincible!
关于气动避震改装控制系统的选择 我是这样看的,玩气动这么多年,还是会有很多网友问,我的车改下来要多少钱呢?钱其实是很主要的因素,都想换最少的钱来换取最高端的气动避震改装。气动避震改装大致分为两个部分,就是控制系统和避震桶身部分,控制系统也就包括打气泵,气罐和控制系统的电子元件还有一些气管和接头一些小的配件,桶身部分也就是避震+气囊。关于控制系统的选择无非就是功能上有一些区别,就看你自己的需要了,是想玩一下简单的低姿态呢还是要更好玩一些。
This is my opinion about the choice of pneumatic shock absorber refitting control system. After playing pneumatic for so many years, many netizens will ask, how much will my car cost after the reform? In fact, money is a very important factor. They all want to exchange the least money for the most advanced pneumatic shock absorbers. The pneumatic shock absorber refitting is roughly divided into two parts: the control system and the shock absorber barrel body. The control system also includes the air pump, the air tank and the electronic components of the control system, as well as some air pipes and connectors, and some small accessories. The barrel part is also called shock absorber + airbag. The choice of the control system is nothing more than some functional differences, depending on your own needs, whether you want to play a simple low posture or to be more fun.
AIRBFT专用气囊:
Airbft special airbag:
Like airbft special car special leather bag, the use of natural rubber ingredients than tire natural rubber ingredients more! Single fatigue times 3 million to 5 million times, normal use of 3-5 years no problem! All the airbags are tested by strict testing equipment to test the pressure, and then they can be sold together! The clamp part of the leather bag is compressed by high-pressure locking equipment, and the normal pressure test is at 200psi, explosion-proof! The outer layer is made of sand and water! Give you the safest protection!
