查看: 716|回复: 0
福特野马改装AIRBFT气动避震悬挂系统施工细节案例
发表于 2020-7-29 11:51:45 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Construction details of modified airbft suspension system for Ford Mustang
新款进口福特野马外形朴实无华,但从骨子里散发着一种野性,毫不矫揉造作的朴实外形,一切以实用为主,是野马的一个突出特点。整个动感好像来自那匹奔驰的野马车标,黑色的蜂窝状散热格栅,更加衬托出镀铬车标的气势来。平淡的前灯组应对整车气势低沉负主要责任。福特野马外形依旧那么放荡不羁。宽大的上下前脸进气隔栅,有助于发动机的有效散热。在一贯的肌肉车线条基础上,增加了许多弧型线条,使整车看上去更为刚毅、强壮,也更具视觉冲击力。美式肌肉车的经典之作——福特野马车型
The appearance of the new imported Ford Mustang is simple and unadorned, but it exudes a kind of wild and unadorned simple appearance from the bone. It is a prominent feature of Mustang that everything is practical. The whole movement seems to come from the galloping Mustang logo. The black honeycomb heat dissipation grille sets off the momentum of the chrome plated logo. The flat front lamp group should take the main responsibility for the vehicle's low momentum. The Ford Mustang was still as wild as ever. The wide upper and lower front air intake grille is helpful for the effective heat dissipation of the engine. On the basis of the consistent muscle car lines, many arc lines are added to make the vehicle look more firm, strong and more visual impact. The classic of American muscle car -- Ford Mustang.
