查看: 864|回复: 0
"黑武士风格“奔驰W213改装AIRBFT气动避震悬挂 低趴效果魅力姿态
发表于 2020-7-29 10:35:09 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Samurai style" Mercedes Benz w213 refitted airbft pneumatic shock suspension low lying effect charm posture
说到W213这一代的奔驰E级,出身名门让它自带气场,其中立标车型更是奔驰最深入人心的形象。如何既保持E级豪华中大型车的气场,又能让自己的个性得以展示呢?本期给大家带来奔驰w213改装故事。
When it comes to the E-Class of the w213 generation, it has its own prestige from a famous family, and its landmark model is the most popular image of Mercedes Benz. How to not only maintain the aura of E-class luxury medium and large-scale cars, but also show their own personality? This issue will bring you the story of Guangzhou car friend a Bo and his landmark Mercedes Benz e320l refitting.
