查看: 775|回复: 0
最为经典的奔驰W211改装AIRBFT气动避震效果分享
发表于 2020-7-29 10:04:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The most classic Mercedes Benz W211 refitted airbft pneumatic shock absorption effect sharing
改装并不是高富帅的专属玩物
改装是一种时尚,一种态度
血液中涌动着机油
如果你也是这样不甘平凡
Oil was surging in the blood
If you are not so ordinary
有些车,天生丽质,但缺少后期塑造,导致淹没在茫茫的车洋中。说到这,也许你会喷WB,车子必须要塑造吗?必须要改装吗?嗯嗯......再天生丽质的女人,如果没有后期的打扮,没有注重穿衣搭配,没有后期的呵护保养,还是一样平平无奇。而被誉为“最美E级”的奔驰W211就属于这一类。车主是怎样的给TA进行后期的塑造,我们一起来看看!Some cars are of natural beauty, but lack of late modeling, leading to drowning in the vast ocean of cars. Speaking of this, maybe you can spray WB. Does the car have to be shaped? Does it have to be modified? Mm-hmm... if a woman with natural beauty is not dressed up in the later stage, does not pay attention to the clothing collocation, and does not have the care and maintenance in the later stage, it is still as plain as usual. The Mercedes Benz W211, known as the "most beautiful E-class", belongs to this category. How does the car owner shape the TA later? Let's have a look!
7:产品优点:方便配合任何一款避震使用,通用性高,可以任意搭配组合,方便做精美的后备箱造型
7: Product advantages: easy to use with any shock absorber, high versatility, can be combined with any combination, convenient to make a beautiful trunk shape
