查看: 891|回复: 0
宝马X5改装气动避震悬挂展现车身完美低趴姿态
发表于 2020-7-29 09:49:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW X5 refitted pneumatic suspension to show perfect low lying posture
新款宝马X5双肾型进气格栅是宝马家族的经典代表元素,在外形方面也要具有一些“肌肉感”。高性能加高实用性,才是它的精髓所在,让X5跋山涉水不在话下。
The new BMW X5 double kidney air intake grille is a classic representative element of BMW family, and it also needs to have some "muscle feeling" in appearance. High performance and high practicability is the essence of X5, which makes X5 go through mountains and rivers.
有车友会有这样的疑问,我的汽车在改装了气动避震后能让我使劲折腾吗?想跟朋友跑到外地去旅游,改装空气悬挂后能长时间的跑高速吗?听说气动避震改装比一般的避震娇贵些,我还能飙车吗?
Some car friends will have such a question, my car in the modified pneumatic shock absorber can let me struggle hard? Want to travel to other places with friends, after refitting air suspension, can you run high speed for a long time? It's said that pneumatic shock absorbers are more expensive than ordinary shock absorbers. Can I drag?
在回答问题之前我们先了解一下为什么有人说气动避震比一般避震要娇贵些,因为气动避震比原厂避震有更加精密的零件,气动避震器上各带有气囊,利用气囊来减震比一般的减震要舒适,毕竟气体比较柔软嘛,成也萧何败萧何,在利用气囊带来的便利时汽车行驶也要有一些局限性,安装了气动避震的车辆只能在道路良好的路段行驶,因为气动避震经不起太剧烈的颠簸,所以一般只要在柏油马路上正常行驶都没有问题,跑跑高速去外地旅游当然没有问题了!
Before answering the question, let's first understand why some people say that pneumatic shock absorbers are more delicate than ordinary shock absorbers, because pneumatic shock absorbers have more precise parts than original shock absorbers. Pneumatic shock absorbers are equipped with airbags, which are more comfortable than ordinary shock absorbers. After all, the gas is relatively soft, and the success is Xiaohe. When the car is driven by the convenience of the airbag, the car will drive There should also be some limitations. Vehicles equipped with pneumatic shock absorbers can only run on good road sections, because pneumatic shock absorbers can not withstand too severe bumps, so as long as they normally drive on asphalt roads, there is no problem in running high-speed travel to other places!
