查看: 796|回复: 0
本田杰德改装AIRBFT气动避震悬挂 领略非凡魅力
发表于 2020-7-27 16:41:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Honda jade modified airbft pneumatic shock suspension to enjoy extraordinary charm
今天带来的,是一款真正的日本本土产品,也是大家可以买到的,它就是 -本田杰德。杰德是什么?你很难定义杰德是个什么车:如果我们将“有三排座椅”都叫MPV的话,杰德确实是个MPV。但杰德的车高很低,只有1米5多,不属于主流MPV的高度。现在三排座椅版本的车也不怎么卖了,大多卖的是5座车。大概我们只能将它归在旅行车类目里 – 虽然杰德并不是一个从两厢/三厢车的原型车改进而来的产品。
What we bring today is a real Japanese native product that you can buy. It is Honda jade. What is Jed? It's hard to define what kind of car Jed is: if we call "three row seats" MPV, Jed is indeed an MPV. But Jed's car is very low, only more than 1.5 meters, which is not the height of mainstream MPV. Now the three row seat version of the car is not very sold, most of the five seat car. Maybe we can only put it in the station wagon category - although Jed is not an improvement from a prototype hatchback / hatchback.
 有人说玩改装是为了装酷/撩妹,有人说玩改装是为了烧钱/追求刺激,每个人走进改装圈的理由并不相同。但大多数人都是浅尝辄止,从不深究背后的东西。就像改装圈里一直盛传着一句话,“百改降为先,一低遮百丑”,气动避震可以说是改装发烧友们最热衷的项目。可有多少人真正把它玩明白了呢?
Some people say that the purpose of refitting is to play cool / seductive, while others say that it is to burn money / pursue stimulation. Everyone has different reasons to enter the refitting circle. But most people just try and never go deep into the things behind them. Just as there is a saying in the refitting circle, "one hundred changes should be reduced to the first, and one low will cover up hundreds of ugliness". Pneumatic shock absorber can be said to be the most popular project of refitting enthusiasts. How many people really understand it?
气动避震属于空气悬挂系统的一种,但用于改装的它,又和普通汽车厂家推出的空气悬挂系统有所不同。气动避震主要是由弹性橡胶气囊减震器、气压控制系统、后备箱储气罐和电子控制系统等组成,它在工作时能够通过控制气压来改变车身的高低。
Pneumatic shock absorber is a kind of air suspension system, but it is different from the air suspension system introduced by ordinary automobile manufacturers. Pneumatic shock absorber is mainly composed of elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system. It can change the height of the body by controlling the air pressure.
至于它的是怎么做到的其实很简单,安装在后备箱的储气罐中,会预先储存好惰性气体。当需要车身升高时,我们可以通过控制电子控制器,给气压控制系统信号。气压控制系统会从后备箱气罐中抽取气体,送入减震器的橡胶气囊中。在气囊的压力缸中,因为气体的充入使得腔体气压增大,从而气囊变硬同时推动减震内的活塞运动,拉长减震升高车身。
反之降低车身时,整个过程相反。由气压控制系统控制减震气囊内的阀体放气,令气体回到储气罐中,同时减震内的活塞会因为气压降低而进行收缩,导致车身降低。
As for how it is done, it is actually very simple. It is installed in the air tank of the trunk, and inert gas will be stored in advance. When the need to raise the body, we can control the electronic controller, to the air pressure control system signal. The air pressure control system draws gas from the air tank in the trunk and sends it into the rubber airbag of the shock absorber. In the pressure cylinder of the air bag, the air pressure in the chamber increases because of the gas filling, so the air bag becomes hard, and at the same time, it pushes the piston in the shock absorber to move, lengthens the shock absorption and raises the body.
On the contrary, when the body is lowered, the whole process is reversed. The air pressure control system controls the deflation of the valve body in the shock absorption airbag, so that the gas returns to the air tank. At the same time, the piston in the shock absorber will contract due to the decrease of air pressure, resulting in the body lowering.
