查看: 762|回复: 0
高端奢华商务奔驰威霆成功改装AIRBFT空气减震器尽显贵族低趴魅力
发表于 2020-7-26 16:59:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
High end luxury business Mercedes Benz Weiting successfully refits airbft air shock absorber to show noble Charm
玩避震的朋友都知道气动避震是最昂贵的,同时也是最娇贵的。
但是它带来的随时升降的乐趣一直是我们津津乐道的话题。
相对于绞牙避震的机械调整,不能随时调整车身高度来应付各种路况,气动避震就能随时调整车身高度的完美姿态来走崎岖的路面。
我们先从它的工作原理来入手,气动避震就是通过气压来控制车身高度的避震器,通过气压来控制改变车身的高低。
它的构成包括弹性橡胶气囊减震器、气压控制系统、后备厢的储气罐、电子控制系统等等。
根据改装的功能,分为避震筒和控制器两个部分。
Friends who play shock absorbers know that pneumatic shock absorbers are the most expensive and the most delicate.
But it brings the fun of rising and falling at any time, which has always been our favorite topic.
Compared with the mechanical adjustment of the hinge suspension, the height of the body can not be adjusted at any time to cope with various road conditions. Pneumatic shock absorber can adjust the height of the body at any time to walk on the rough road.
We start from its working principle. Pneumatic shock absorber is a shock absorber that controls the height of the body through air pressure, and changes the height of the body through air pressure.
It consists of elastic rubber airbag shock absorber, air pressure control system, air tank in the rear compartment, electronic control system and so on.
According to the function of the controller and the shock absorber, it is divided into two parts.
