查看: 846|回复: 0
“运动精神始终如一 ”宝马3系AIRBFT空气避震改装案例 低趴风格魅力的展现
发表于 2020-7-26 15:59:15 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Sportsmanship is always the same" BMW 3 series airbft air shock absorber modification case
宝马3系向来被冠以“驾驶者之车”的名号,坊间也早就流传着“开宝马坐奔驰”的说法,宝马的操控性与运动偏好无需置疑,而3系无疑又是其中之最。自1975年诞生至今,宝马3系走过了将近半个世纪的征程,始终如一的运动精神可谓代代相传。所以在最新的第七代3系(G20)上市之前,我们有足够的理由来讲述宝马3系的前世今生。
BMW 3 series has always been known as "the driver's car". It has long been said that "driving a BMW in a Mercedes Benz" has long been popular in the market. BMW's handling and sports preference need no doubt, and the 3-Series is undoubtedly the best among them. Since its birth in 1975, the BMW 3 series has gone through a journey of nearly half a century, and its consistent sportsmanship can be described as handed down from generation to generation. So before the launch of the latest 7-generation 3-Series (G20), we have enough reason to talk about the past and present life of BMW 3-Series.
