查看: 990|回复: 0
“大佬气息十足”宝马E38改装气动避震悬挂精选优质案例
发表于 2020-7-26 15:42:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Big man's breath" BMW E38 refitted pneumatic suspension
宝马E38给我留下深刻的印象还得归功于《非常人贩》这部电影,杰森·斯坦森驾驶的那台6速手动的E38无论是谁都无法追上他,并且这台车也是仅有的一台手动变速箱的750i。而今天的这个主角E38依旧非常经典。
I am deeply impressed by BMW E38, which is also attributed to the movie "unusual people". Jason stanson's 6-speed manual E38 can't catch up with him, and this car is also the only 750i with manual transmission. And today's main character E38 is still very classic.
From the first time I saw the car refitted with pneumatic shock absorber to now, I am deeply trapped in it, and I have experienced a lot of twists and turns! Also learned a lot about pneumatic shock absorber refitting knowledge!
气动避震的组成部分分为控制系统和气动避震桶身两大类!
